Wideband & EGT - one or two or each?
Nissan 350z / Nissan 370z general community discussion forum
jjdarkstuff
Car: 2004 z33 (SC) - 1995 240sx Drift - 1992 s13 Coupe (weapon will be done soon)
Just wondering - as I've only had them on single turo applications????
It think I may set up two for tuning, make sure each bank is acceptable AFR etc, then just plud up the bungs afterward.
I just really need to see my AFR / EGT on anthing FI, not sure if running one on each header is worth it.
Oh, it's supercharged - with a borla true dual
JETPILOT
The only option you asked about that is really mandatory would be a single wideband on one or the other bank. Whatever is happeneing on one side is happening on the other. I wouldn't bother with EGT.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I believe they are batch fire and iff not most aftermarket systems do not allow you to tune "req fuel" on a cylinder by cylinder basis, so just one WB is all you nee,d the EGT is more of a turbo health thing, not really a tuning tool
JETPILOT
The EGT gauge is used for tuning ignition timing. Pulling timing increases EGT.
jjdarkstuff
Werd....I'll probably stick with one WB, no EGT until I get my turbo setup (well if I get my turbo setup )
I've got access to a Dyno next door, and some really good tuners that will help me out.
I've never used an EGT for tuning, but I'll definately research that. I may put one in now to test that theory, thought EGT's and WB's are friggin expensive
Return to “350z / 370z Discussion”
