So you're saying you're using PS fluid and not ATF right now???
I'll let others weigh in here, but I'd sure get that stuff out of there before you drive it again. From what I understand the seals, pump, etc. are set up for the specified fluid, and there's a lot of difference between the two!!!
Might need to save for a steering system overhaul instead of the new interior you've been talking about
Heath
