whirrling clutch
dreamsOfSkylines
When my car idles in neutral with the clutch pedal up it makes a faint whirring noise. I can only hear it when I'm in a quiet place (no traffic). Is this something to worry about, could the cluth be misaligned? Thanks for any help...
dreamsOfSkylines
bump
180crafter
Car: Nissan 240sx
Could be the Throw Out bearing. Had the same problem. If it gets worse, I would change it.
bruinbear714
180crafter wrote:Could be the Throw Out bearing. Had the same problem. If it gets worse, I would change it.
Yep, its the throw out bearing. It's not a big deal, but it's usually a sign that your clutch will start to slip soon.
nismofan14
yeah i installed an act stage 2 4puck disk and heavy duty pressure plate......in the process my friend happened to forget to replace the throw out bearing.....nuttin like removing the transmission twice.
