Which speed sensor do I need?
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
Datto
Car: Datsun 620
I have a 72 Datsun 620 that I ka24de swap off a 91 s13 and I want my mph gauge to work, so I was hoping someone here has solved this issue. tnx in advance....
Reason: TYPO
NL320what
Car: '63 Datsun NL320 4x4
'04 GMC Yukon
'13 Chrysler 200 Touring
Datsun 620 Spedo dont use a speed sensor. You would need the Spedo from the 240SX cause its matched to the trans and figure out any wiring needed.
importer
Car: Cressida & Datsun 620
You just need to run down a 71C trans that uses a cable driven speedo.
Once you have those parts, possibly the tail shaft housing, speedo drive gear, speedo driven gear & holder of the correct tooth count for your rear end ratio.
I know that there were cars with the 71C that used cable driven speedometers.
That way you don't have to butcher the dash to fit a later gauge.
Return to “Datsun 620”
