silver2k2 »
https://forums.nicoclub.com/silver2k2-u57091.html
Thu May 17, 2007 5:56 pm
So I got my rebuilt pump today and put the Hicas pump pulley on it. As I hoped it bolted right up. Its the same with as the active pulley so the same belt, idler, water pump pulley, and crank pulley should work. its 5 15/16 in diameter.
I am not sure the size of a reg pulley does anyone know?
I cant see any problem running the wider belt.
If the pulley is larger it will spin the pump slower, if its smaller it would drive it faster. I need to know how big the reg pulley is to know how much.
Not sure if it would matter too much either way.
