cnichols »
https://forums.nicoclub.com/cnichols-u493.html
Tue Aug 26, 2008 7:49 pm
Some might disagree, but in order to get the majority of the needed parts and not have to hunt for odds and ends in order to piece together your swap, I recommend an F-body pullout complete with engine, tranny, accessories, etc. so that you have almost everything you need and don't need to do as much work.
However, truck engines are very cheap and are a good way to cut costs if you don't mind the hassle of tracking down a manual tranny (if that's what you want), the F-body accessories, LS intake manifold, etc.
Hopefully the list below will help in the search for the right engine for your project....
GENERATION III - I recommend sticking with the Gen III engines due to the large production#s and the resulting cost effectiveness.
LS1 - 5.7 (346 CI) - Between 305-350 hp and 335-375 ft·lb1997-2004 Chevrolet Corvette C5, excluding Z06 1998-2002 Chevrolet Camaro Z28, SS 1998-2002 Pontiac Firebird Formula, Trans Am, Trans Am WS6 2004 Pontiac GTO *97-98 Had Perimeter Bolt Valve Covers
LS6 - 5.7 (346 CI) - 385(01 Vette only)/405 hp and 385(01 only)/400 ft-lbs.2001-2004 Chevrolet Corvette C5 Z06 2004-2005 Cadillac CTS V-Series
*Basically the same as an LS1 but with better heads (243 head castings) a more aggressive cam, and LS6 intake manifold make up the power differences.
TRUCK ENGINES - STILL GENERATION III - 285-295 hp and 325-335 ft·lb
The truck engines are very much like the LS1/LS6 and are still classified as a Gen III engine. They are mainly iron with the exception of the LM4/L33, and as a result weigh approximately 80+ lbs. more. All the parts from the LS series can bolt on to these engines and is recommended for any swap as the accessories and intake manifold usually fit better from an F-body. The 4.8 and 5.3 can both be punched out to a 5.7 (346 Cubic Inches) simply with a bigger bore (the 5.3) or a bigger bore and the 5.3 crank (in the 4.8's case).
4.8 - LR45.3 - LM4, LM7, L33, L596.0 - LQ4, LQ9
LR4 - 270-295 hp and 285-305 ft·lb*Iron Block 2003-present Chevrolet Express 2500-3500/GMC Savana 2500-3500 1999-2007 Chevrolet Silverado/GMC Sierra 1999-2006 Chevrolet Tahoe/GMC Yukon
LM7 - 285-295 hp 325-335 ft·lb *Most common 3rd gen LSx engine - Iron Block2002-2005 Cadillac Escalade 2WD 2002-2006 Chevrolet Avalanche 2003-2007 Chevrolet Express/GMC Savana 1999-2007 Chevrolet Silverado 1500 1999-2007 GMC Sierra 1500 1999-2006 Chevrolet Suburban/GMC Yukon XL 1999-2006 Chevrolet Tahoe/GMC Yukon
LM4 - Identical to the LM7 in power/torque*Aluminum Block, limited production2004 Chevrolet TrailBlazer EXT 2004 GMC Envoy XL 2004 Chevrolet SSR
L33 - 310 hp - High Output version of the LM7*Aluminum Block2005-2007 Chevrolet Silverado 1500 4WD 2005-2007 GMC Sierra 1500 4WD
L59 - Flex Fuel version of the LM7 (power/torque same)2002-2007 Chevrolet Silverado 1500 2002-2006 Chevrolet Tahoe/GMC Yukon 2002-2006 Chevrolet Suburban/GMC Yukon XL 2002-2007 GMC Sierra 1500
LQ4 - 6.0L (364 CI) - 300-325 hp / 360-370 ft·lb*Iron BlockChevrolet Express/GMC Savana Chevrolet Silverado 2500 Pickup, 3500 Pickup, Crew Cab, and Chassis Cab/GMC Sierra 2500 HD Pickup and Crew Cab, C3, Denali, and 3500 Pickup and Chassis Cab, 1500HD Crew Cab Chevrolet Suburban/GMC Yukon XL Denali Hummer H2 SUT GMC Yukon Denali
LQ9 - 6.0L (364 CI) - 345hp / 380 ft·lb*Iron Block2002-2006 Cadillac Escalade 2002-2006 Cadillac Escalade EXT 2003-2006 Cadillac Escalade ESV 2003-2007 Chevrolet Silverado SS 2004-2005 Chevrolet Silverado and GMC Sierra Vortec HO Edition Only 2006-2007 Chevrolet Silverado and GMC Sierra VortecMAX Option
GENERATION IV - Generation IV engines are very similar to Gen III and some parts can be interchanged. The Gen IV was produced with displacement on demand and variable valve timing in mind. Not all have these features, but they are available.
L76 - 360hp /385 ft-lbs. 6.0L (364 Cubic Inches)2008 Pontiac G8
L98 - 362hp /391 ft-lbs. 6.0L (364 Cubic Inches)2007-2008 Chevrolet Lumina SS 2007-2008 Chevrolet Caprice SS
L99 - 400hp /395 ft-lbs. 6.0L (364 Cubic Inches)*Derived from the LS3 and with Displacement on Demand2010 Chevrolet Camaro
LS2 - 6.0L (364 CI) - 400 hp/400 ft.-lbs.2006-2007 Cadillac CTS-V 2005-2007 Chevrolet Corvette 2005-2006 Chevrolet SSR 2006-2008 Chevrolet TrailBlazer SS 2004-2007 Holden Special Vehicles (all V8 models) 2005-2006 Pontiac GTO 2008-2010? Saab 9-7X Aero 2005-2006 Vauxhall Monaro VXR
LS3 - 6.2L (376 CI) - 430 hp / 424 ft.-lbs.
April 2008-present Holden Special Vehicles (all V8 models) 2008-present Chevrolet Corvette 2009 Pontiac G8 GXP 2010 Chevrolet Camaro
LS4 - 5.3L (325 CI) - 303 hp / 323 ft.-lbs.2006-2008 Chevrolet Impala SS 2006-2007 Chevrolet Monte Carlo SS 2005-2008 Pontiac Grand Prix GXP 2008 Buick LaCrosse Super *Aluminum FWD Block w/ LS6 Heads
LS7 - 7.0L (427 CI) - 505 hp / 470 ft.-lbs.2006-2008 Chevrolet Corvette Z06 2008 HSV W427
LS9 - 6.2L (376 CI) Supercharged - 638 hp / 604 ft.-lbs.*Based on the LS32009 Chevrolet Corvette ZR1
TRUCK ENGINES - GENERATION IV
LY6 - 6.0 (364 CI) - Same as LQ4, but Gen IV.*Variable Valve Timing2007-present Chevrolet Silverado HD 2007-present GMC Sierra HD 2007-present Chevrolet Suburban 3/4 ton 2007-present GMC Yukon XL 3/4 ton
L76 - 6.0 (364 CI) - 367hp / 375 ft.-lbs.*Basically the Gen IV replacement for the LQ9*Variable Cam Phasing & Active Fuel Management2007-present Chevrolet Suburban 2007-present Chevrolet Avalanche 2007-present Chevrolet Silverado 2007-present GMC Sierra 2007-present GMC Yukon XL
LFA - 6.0 (364 CI) - 332 hp / 367 ft.-lbs.*Active Fuel Management*Late-intake valve timing system*Higher 10.8:1 compression ratio2008-present Chevrolet Tahoe Hybrid 2008-present GMC Yukon Hybrid 2009-present Cadillac Escalade Hybrid 2009-present Chevrolet Silverado Hybrid 2009-present GMC Sierra Hybrid
L92 - 6.2L (376 CI) - 380/403 hp and 403/415 ft.-lbs. 2007+ Cadillac Escalade 2008+ Chevrolet Tahoe 2007+ GMC Sierra Denali 2009+ Silverado 1500 2008+ Hummer H2 2007+ GMC Yukon Denali/Denali XL
Quick summary of the major engines and their compression ratios and GM part #s:
LS1...346c.i. 5.7liter 10.19:1 25534322LS6...346c.i. 5.7liter 10.46:1 12578104/12562190LR4...293c.i. 4.8liter 9.47:1LM4...325c.i 5.3liter 9.49:1LM7...325c.i 5.3liter 9.49:1 12562201L59...325c.i. 9.49:1LQ4...364c.i. 6.0liter 9.41:1 12575147/12575148LQ9...364c.i. 6.0liter 10.08:1 12499467
