nismo1003 »
https://forums.nicoclub.com/nismo1003-u8632.html
Sat Nov 01, 2003 9:15 pm
what I was thinking was:
E-manage - Control the injector pulse (adjust for the bigger injector), retard the timing , mointor the oem maf so i won't go over 5.0v out of the stock ecu fuel map?add additional fuel map?
FMU- Increase the Fuel rail pressure. 255 fuel pump- flow more, higher pressure for the fuel system. so are you guys saying the stock ECU with e-mange would control the stock Fuel pressure regulator ?
I've already installed both unit E-manage and FMU . can I just use both? safer?
also I have got the Fram HPG1 , I got it for a good deal (new for 24.99) can i just use it instead of my stock one? how much fuel pressure I should expect in Idie and running 2000rpm 3000rpm 4000rpm 5000rpm 6000rpm
my car should be able to start on tuesday, can anyone tell me where I shoudl put the MAF at( before or after the compressor) for tuning?and normal driving?. I am using a T3 , I guess it's not a problem if I just put it after the compressor right?I am justy worry if it can't read the boost if I put it befor ethe compressor, correct me if I am wrong. Thank you once again for all the input! once I get it start it I will let yo know ...another Ka TURBO ^_^
