Where to run mechanical water temp sensor?
kpc_0721
Car: 1991 240sx hatchback
Just picked up a autometer cobalt mechanical water temp and just curious if there is anywhere it will actually screw into or fit in because im not a big fan of tapping into my hoses....
kpc_0721
bump
gumby74
There is an adaptor for the fan temp sensor located on the lower rad. hose. Find one at a salvage yard and splice that into the upper rad. hose. The included adaptor (should be a blue insert that came with the gauge) will thread into this sensor hole.Don't know if that made any sense. Just eyeball your lower radiator hose and the hardware that came with the gauge and you should be able to figure it out.
kpc_0721
yea only thing is I dont wanna go in through the hose if there is another way where it can just screw in? If I have to though I will just order a adaptor peice for the sensor.
DALAZ_68
Car: 90' 240sx CA18det
bro justdo what gumby74 suggested...
all u have to do is cut ur upper hose to revome a section off and put that pipe in there with the temp prob and boom u got it...
coolbone28
You can also put the sensor where the bleeder plug is on the upper rad hose. You might have to re-tap it to fit the threads of the sensor. Thats usually what a lot of people do.
cmoody2006
Car: 1993 Nissan 240sx vert
