Where to find full CA18DET gasket set??
T-u-R-b-O
Car: Nissan SX CA18DET
hi fellas ... title says it all...
and yes i went to nissan , but they want 380 euro for the f+++ing set - around 500 bucks...
so where to looks for some normal good quality gasket set, where i dont have to pay a fortune for the brand?
thx!
nick
originalsin
go to autozone and get a head set for a ca18de, same thing
8ggalant
Car: nissan cefiro
lol im not sure he has an autozone, unless you mean teh website *shrug*
dvd
originalsin
o **** lol, dident even notice that, well if ya want ill order it up and ship it and all that as long as you front the money paypal er sumthin
biosehnsucht
man they rape you over there.
here from courtesy I think I spent less than that I think for full top to bottom gaskets AND new oil and water pumps and thermostat all OEM..
T-u-R-b-O
is the ca18de really identical to the det? cause i have seen picts from the intake manifold, and it seemed slightly different... and does it also have those nice metal gaskets between the block and exhaust manifold like the det version...
and i believe that the set for the ca18de doesnt incl. the 2 gaskets which are needed to connect the turbo?
thx for the help guys!
nick
btw, i'm from vienna in austria (a little country next to germany ) :-)
biosehnsucht
there are some differences w/ the manifold and such but IIRC the gaskets work.
you might try emailing courtesy nissan (www.courtesyparts.com) and see what it costs to have them ship you the parts you want, might be cheaper than the gouging you get there.
There won't be the turbo gaskets (turbo to exh manifold and turbo to downpipe) but the turbo to exh mani I think you can use from a Z32 or Z31 I forgot which (ordinary T25/T28 series gasket) and the back side IIRC there wasn't a US equivalent but its just a normal T25/T28 5 bolt gasket, I'm sure someone there can get them.. I think anyways
Vetal
Biosehnsucht, I didn't find CA18DE(T) on http://www.courtesyparts.com, please point me
Vetal
Will these Topline CA18DE gaskets work?http://www.importperformancepa....htmlPULSAR SE, CA18DE, 1809cc , CGSD27L $109?
Vetal
Or where can I order this set "Engine gasket kit 10101-56E25 (CA18DET)" which is in sticky threads?Please help, my local Nissan dealer wants smth. like 250$
Vetal
Guys, please help me with this... Still not sure about gasket sets for CA18DET...
pulsar gtr
Car: NISSAN VEHICLES
I can get you a set here in Canada and have it shipped to you.
Here are some prices of some gaskets that I got in the past
Valve cover gaskets are 15 dollars each (you need two)Valve cover half moon pieces 1.50 a piece (you need two)oil pan gaskets 3 dollars each (you need two, front and rear)Rear main crank seal 16 dollars oil pump 280 Water pump 65
Front main seal, camshaft seals total you need 3 of them, don't have the exact price, but I will say 10 dollars each to be on the safe side.intake gasket set rougly about 20 dollars headgasket roughly about 100 dollars
Total is around 550 dollars but that includes the oil pump, water pump and headgasket.
550 Canadian is roughly about 350euro, if you don't want the oil pump, water pump ,headgasket, just calcuate the above price.
not sure how much you guys can get the oil pump in the USA, any ideas, I find it pretty expensive for the oil pump here in CanadaRemember all the prices are in Canadian currency.If you are interested, I can buy it and have it shipped to you.
PULSAR GTR
c-rad
Car: 1991 Nissan 240SX w/CA18DET
NeedCAforS13
Car: CA swapped S13 coupe
T-u-R-b-O wrote:380 euro for the f+++ing set - around 500 bucks...
thats really not bad for a top to bottom Nissan OEM quality engine gasket set...
Sean
biosehnsucht
Don't recall off hand how much my oil pump was but I'm certain it was under $200 for sure. I have all the receipts for all the bits and peices but it'd take awhile to find.. once I have my car 100% for a bit I'm going to take the time to go through them all and see how much money I spent and on what
Vetal
Pulsar: thanx for your offer I will keep it in mind c-rad: so I guess CGSD27L would be the right number for full set?
Vetal
Is this set the right one?http://www.trademotion.com/par...gid=1First one for $168.10?
Vetal
bump
Vetal
sorry to bump once again...
Vetal
bump N3...
CA19DET
i can get a full kit from my local Nissan dealer for about $250 US including HG etc
then i have access to the AJUSA kits for the 4 port engine (uk) about $50-$200 US... depending on which kit you need, i also have about 4 gasket kits home in different states, lol what gaskets you need??
i can look into it if you wish..
Vetal
Thanx, but, I just wanted to know whether their "overhaul gasket set for CA18DE" for $168 is what I need for rebuild
Vetal
Anyone?
Vetal
Guys please anyone confirm that this set for CA18DE from Everythingnissan.com is what I need... I wouldn't want to throw away $170 and couple of weeks for incorrect set... Help!
NeedCAforS13
Holy crap!!! The reason no one answers you is because it has been said a million times that a pulsar CA18DE gasket set works. Any year CA18DE pulsar gasket set works. Does the everythingnissan.com gasket set work? Hell if I know. If no one has ordered it before we can't tell you 100%, but since CA18DE gasket sets are the one you need, it would make sense that that's the one you need!!!
Sean
