VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Wed Oct 20, 2021 9:45 am
Once parts are out of production and stock is exhausted, you're pretty much out of luck unless the aftermarket picks them up. That rarely happens with door hardware, so if the JY isn't an option for you, you'll almost certainly need to modify or fabricate something. One suggestion I'll offer is that left/right cylinders often differ only in the direction of the actuator arm, so take a look at the ones you have and see if the arm can be removed and relocated 180 degrees. If so, you can probably turn a passenger part into a drivers. If not, you may need to find a similar part that fits in the same outside hole (say, from a Sentra) and modify it.
