repo man wrote:Also consider HJC helmets. Good helmets and very well priced. I got mine for $160 and it carries the Snell 95 rating. I would suggest going to a good motorcycle shop and being fitted by a pro as I did. Proper fit is something that many people overlook but will make a big difference if the helmet actually has to protect your nugget. I was fitted by the local Harley shop and they took excellent care of me.
I picked mine up for roadracing too, but wear it at the strip as well.
My girl got me one in perfect condition for 25$ at some local thrift store hehe. HJC snell M95** black full faced. It was a split second buy and she brought it home. It happened to be the correct size and all. I only run it at the auto-x's but its a nice comfotable fit.
As far as saftey gear goes they may or maynot be so anal about it. Here at OSW they dont do a thorough tech of the car at least on the test and tune nights, aka street drags. If you run 13.9 and faster they require a helmet, and if you run 11.9 they will require a roll bar. As for the driveshaft loop they have never looked for his (as he doesnt have one) and runs consistent 12.1's in his stock turbo'd z32. This weekend he should be hitting 11's though easilly as he's running 110, 17 or so lbs, 720 injectors and a host of other things on a stock ignition and thats what we are putting in tommorow night. He constantly loses a cylinder down the track due to this.
They may check for these things after his 11's constantly but all they check for now is a helmet. So unless you go to some big event they may not even check these things untill you get pretty quick, like Jay quick.
** the snell95 everyone is refering to can either be SA (snell auto) or SM (snell motorcycle) and the # refers to the year. Auto-x only requires any snell helmet from 90 up or a sa90 / sm90. I would check to see what you need as most open track and drag sanctions will require a "SA" and some year (90 95 00).
The reason for this is the liner. The SA have nomex liners, while the SM have a cheaper nylon liner. The reason is that on a bike you are unlikely to be pinned under it in case of a fire. Nylon if burned will stick to your face, which isnt so good for the medics to try to get it off if its melted to you. Nomex is safer and doesnt have the same properties thus is used in the automotive helmets, where the chance of personal containment in a burning vehicle is much greater.
The nomex will set you back more but you will be nearly 100% sure you wont have a problem with it on anytrack, as long as you get a newer year model.
Hope this helps.
Edit: just read that not only does the SA cary a flamability test it also carries a rollbar impact test. Obviously a motor cylce wont need a rollbar test but if you plan on getting a roll bar / cage,it might be nice to know that the helmet you by can withstand direct hits to the cage. They both carry the same impact tests, but the SA has these extra. The extra tests and nomex are what makes the price slightly stteper.
