is the Ca even banjo bolted? i thought there was a 90° pressure reduction fitting that was threaded into the block, then the oil line was threaded into that.
Are you guys sure your not thinking of the coolant lines? I have the braided steel lines and the coolant line threads into the 90 degree fitting, the oil lines way too small. Its an SR turbo if that makes any difference.
