AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Fri May 27, 2005 6:21 am
Easy to remove.
Crawl under the rearend. It's a bar that runs perpendicular to the driveshaft (left to right) and has a bend at each end (bent towards the front of the car).
It SHOULD be the "lowest-hanging" item in the rear, about the thickness of your thumb. You'll see it.
Two U-shaped brackets hold it to the frame, and an endlink on each end. Make sure you get ALL the hardware with it (bolts, brackets, endlinks, bushings, nuts, cupwashers).
