Hello!
Where is the fan relay on a 2008 G35? All I found was a 50A fuse in the smaller fuse box in front of the battery. And next to the battery, I didn't see anything that was for the fans. Is there some other location that has this relay?
Coolant temp sensor works, fans work because I can turn them on with my scan tool. wires have voltage running to the fan module..... This is annoying, normally cars have either one relay, or two for high and low speed.
Thank yoU!!
