Where is the ECU on a CA18DET
Ca_Silvia
Like it says above, on a S13 silvia were is the ECU located, also do you check codes in the similar way you check codes on a R32?
capwred
its on the lower kick panel on the left side
Ca_Silvia
capwred wrote:its on the lower kick panel on the left side
Is it like an R32 ECU that "blinks" out the code in flashes?cheers
float_6969
exactly the same. If you read the FAQ at the top of this forum, it talks about how to perform this test. I don't see any reason why it would be any different from an R32 though. There is also a link up there to download the FSM in english from.
On a side note, WELCOME TO NICO!!!
