mikehutch711 »
https://forums.nicoclub.com/mikehutch711-u15711.html
Mon Jul 25, 2005 5:55 pm
Heres some pics for u, i brightened them out alot to make it eaiser to see where the hoses connect. this one goes to the top facing port of the air regulator
this one goes to the bottom facing port of the air regulator
Now, before I had it hooked up from the 1st circled place >to> air regulator >to> 2nd circled pipe. Car ran perfect for a month or 2, then it just refused to idle.
After much research, discussions with rafi and looking over the CA18der fsm, I teed that second line that comes off the bottom of the Air Regulator into a pipe I had welded onto my cold pipe. Result = perfect idle all the time.
Hope this helps.
