Where can i get a brake fluid reservoir cap for my 80 720??
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
JoeCool6972
Car: 2017 Infiniti QX50
I need a brake fluid reservoir cap for my 80 720. Mine has two metal caps on the master cylinder with rubber plugs underneath. The front one the plug is split and the cap won't stay on. It currently has a zip-tie holding it on done by a previous owner. Last owner said he never could find one, and also left the fluid alone the three years he had the truck. I have been to the two local Nissan dealers, and all the parts stores in the area.
PEZi
All I can think of is a junk yard if no one locally has it. The dealerships weren't able to source it from anywhere else? I know my dealer never has anything for my truck, but they can usually source it from somewhere.
N-Dually
Car: 1986 Nissan 720 Dually
I would try a local Pull-A-Part if you have one. I have scored many parts there. Good luck!
fastboatman29212
Car: left this forum. Sold my truck.
JoeCool6972 wrote:I need a brake fluid reservoir cap for my 80 720. Mine has two metal caps on the master cylinder with rubber plugs underneath. The front one the plug is split and the cap won't stay on. It currently has a zip-tie holding it on done by a previous owner.
My local PullaPart has a recent 1976 Datsun truck. Do you think the brake reservoir is the same as a 76? If so, I'll stop in and have a look.
JoeCool6972
Honestly, I have no idea.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
check with our classified section too maybe someone is parting out or sometimes people just come across this and that. You'll find the damnedest things from these nico fellers :D
fastboatman29212
JoeCool6972 wrote:Honestly, I have no idea.
I hate to be stubborn, but you'll need to post a photo with views from different angles and maybe some measurments of the cap you are looking for. That way if I stumble across it at the salvage yard I will know what to buy. Otherwise I'd waste money by guessing and buying the wrong part.
Can you post some photos and give me some measurments?
JoeCool6972
Honestly, unless it's a fender, bumper or some other body part, I don't trust parts from junkyards. As a professional mechanic I have seen too much failure of junkyard parts.
I found one here: http://www.nissanpartszone.com
$10 brand new plus shipping
This site has a lot of new genuine Nissan, old stock, and reproduction parts for old Datsuns and Nissans.
fastboatman29212
OK, Just trying to help. That site you posted looks like a good resource.
86 720
Car: 1986 720 4cyl Standard Cab
Just get a new reservoir tank. It isn't all that much, plus you'll get a new one with a warranty. It's really easy to install!
master-cylinder-replacement-t523910.html
Return to “Datsun 720”
