When it rains it pours! 1996 nissan 240sx SE KA24DE Engine Problems!
XerouShift96S14
Car: 1996 Nissan 240SX SE Model (Leather interior, ABS, and VLSD Equipped)
Alright, it'll crank and turn over, then the idle is at 2k, drops to 500, it'll shudder and die, does it within seconds of starting.
Went to autozone and got a code read, below are the codes it listed, maybe you guys could figure out which exact parts to replace/fix?
P0443: PCM Malfunction in electical circuit for the purge control valve in the evaporative emission control valve.
P0105: PCM has determined a malfunction exists in the electrical circuit for the manifold absolute pressure sensor or barometric pressure sensor.
P1105: MAP/BARO Pressure Switch Solenoid Valve
p1400: EGRC Solenoid Valve
So, I figure you know where there are on a stock KA24DE, pics if possible, need to get my car finished so I can resume working, already looked at the FSM but I kinda got confused staring at it.
Help please?
