Wheel downsizing
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Eric.
Car: 2016 Infiniti QX50 RWD
Wheel downsizing
Postby Eric. » Tue Aug 25, 2020 11:17 am
I have a '16 with factory 19" wheels and reasonably complaint tires (Michelin Primacy MXM4s). Even so, the ride is too brittle for my tastes. It rides less comfortably than my old G35S. I've played with pressures, and that doesn't make much of a difference. I'm sure some of it has to do with the suspension, but still. It's not great.
Has anybody downsized to a 17" or 18" wheel? If so, did the extra .5-1" of sidewall make a noticeable difference? I've never driven a QX50 with the 18" wheels, so I have nothing to compare to. I'd go with something used from Infiniti, likely off of a Q50.
Car: 72 240Z RB25, 63 Bluebird RHD, 63 NL320, 67 WRL411, 67 SPL311, 68 510 SR, 77 620 SR20, 97 D21, 98 S14, 11 LS460L, 12 Titan 4x4, 20 MX5 Club.
Re: Wheel downsizing
Postby AZhitman » Tue Aug 25, 2020 1:24 pm
Definitely doable, and a 17" wheel with taller sidewall will definitely result in a smoother ride. The Primacy aren't super-soft, so that's not helping.
I'd look at whatever's on the "base" model QX50 and go with that package, because you know the overall diameter will be the same, and clearance will be good.
I'd bet money someone out there is willing to do a trade, especially 17" for 19". Craigslist (or here) are good places to start.
Eric.
Postby Eric. » Wed Aug 26, 2020 6:54 am
Thanks for the info. I'm not a huge fan of the 18" QX50 wheel design, otherwise I'd definitely go that route.
My other thought was to replace the Michelins (they have 3k miles, so are worth a bit used) with something like a P-Zero A/S Plus, but at that point, I'm half way to smaller wheels and some more sidewall. In addition to ride quality, smaller wheels/tires will improve MPG a touch and maybe give me back some steering feel. Ill probably go 235/50 18... not exactly the same OD as the 19s, but there's a lot of options vs. the slightly taller sidewall 225/55 18" OE size.
LQQX50
Car: '16 QX50 Malbec Black 3.7 325HP
Postby LQQX50 » Thu Dec 10, 2020 1:54 pm
The Tires are too NARROW ~ Resulting in a less than desirable feeling of sure-footedness.
My '16 with the 19" OEM Split 5 Spoke came with OEM Bridgestone Turanza EL P245 / 45 / 19 tires.
Road grooves and surface imperfections seem to just swallow up the narrow tires and send feed back to steering wheel.
With just 13,000 miles on the car and original tires, I can wait to to get wider tires when replacement time comes.
That will be my route to attempt to improve the ride quality and gain a sense of better handling.
Nothing like a Pandemic to keep me working from home and away from putting on fun commuting miles on the QX50 . . .
Agreed, the Factory 18" wheel looks old and tired as it's been around since '07, the 19" looks a bit better, but still lacks a " Beefy " appearance.
Check out some wheels from other Infiniti or Nissan Models :yesnod Believe it or not, some newer Murano Designs would look good on your '16 QX50 :dblthumb:
Postby AZhitman » Thu Dec 10, 2020 5:52 pm
^ Good suggestions.
Keep in mind, too much wider can lead to tramlining or too much sidewall flex (tires should be within the recommended size for the wheel width).
Too narrow is no good either. Don't stray too far from the original OD, as that's what the ABS and TCS are calibrated for, as well as your speedo and odo - It'll cause all sorts of mayhem if you get too far out of spec.
LQQX50
Postby LQQX50 » Fri Dec 11, 2020 2:58 am
Agreed on not straying too far from factory tire Dimensions, especially the OD.
As far as width goes, the Bridgestone Turanzas that came on the car from Japan are 27.7" OD x 8.2" Wide
Tire Rack Consumer Reviews rip them them apart too for multiple reasons besides my gripe of feeling " too narrow " for the car.
Come replacement time, won't stray too far for original specs in OD, but will go with wider width up to an inch.
If ever bored and want to tire shop online :crazy: the varying consumer reviews that praise and slam the same tire are all over the place.
One other note . . . Proper inflation is key to reducing ware and keeping up optimal handling . . check tire pressure often and keep it at the recommended PSI . . . it really is amazing how just a few pounds difference can affect handling manners.
3144
Car: 2002 Maxima, 1998 Infiniti QX4
Postby 3144 » Wed Mar 17, 2021 9:15 am
I have 2015 qx50 with 24000k and it tramlines real bad. Took it to infinity they did 4 wheel alignment, rotated tires and it still does it. They said the stock bridgestones 245/45-19 are bad for tramlining, so when i got home i replaced them for 2007 maxima rims and firestone tires 245/45-18. These tires while driving maxima were great so i assumed when on qx50 it would be fine.
Took car for a test drive on highway and it did it again. Now I'm not sure what's next because downsizing did not work. :wtf2:
rp_guy
Car: QX50
Postby rp_guy » Sun Mar 21, 2021 3:42 pm
Take it back.. I never had an issue with the stock size
Return to “Infiniti EX35 / EX37 and QX50 Forum”
