Wheel Bearings
1dollar240
Has anyone ever changed wheel bearings on their s13? I've got a pretty bad squeak and I'm hoping its gonna be a simple brake job but I will find out this weekend when i take it all apart. Im just curious as to how much is involved in installing new bearings.
Just another 240
i believe is press in and press out, come to think of it i never changed wheel bearing before. dOH!
bp2ooo
Back in the day, before i would dare work on a car i had one done. Dont know exactly how to do it but it only cost my 150 with labor. When i checked autozone at the time just the part was like 130.
erich
The wheel bearings are supposed to be 'lifetime' of the car, according to the FSM. I believe that the rears can't be replace without replacing the entire assembly. I can't remember about the front, but I think it's the same deal.
float_6969
I've never heard of anyone haveing them going out on a 240, hmmmm. I've done them on a 63 Plymoth Grandy Fury III about a million times, but those were designed to come out.
bp2ooo
well i had my front drivers side one replaced. I saw the part, and the guy that did it is a friend of the family. He told me they normally dont go bad, but i was just lucky.
SmithSR
Car: 240sx
erich wrote:The wheel bearings are supposed to be 'lifetime' of the car, according to the FSM. I believe that the rears can't be replace without replacing the entire assembly. I can't remember about the front, but I think it's the same deal.
"Lifetime" is the improper term here. a better explanation would be to say "non-seviceable" or "sealed-bearing assy". please be aware that bearings can and do fail, and usually require press-fitting, aka not a backyard job. take it to a reputable shop in your area.
PabloHoney
THe wheel bearings are inside the hub AFAIK, so you can just replace the hub (which is easy work).
1dollar240
Quote »THe wheel bearings are inside the hub AFAIK, so you can just replace the hub (which is easy work).[/quote]
what does afaik mean?
