chris1212 »
https://forums.nicoclub.com/chris1212-u193723.html
Sat Feb 23, 2013 3:44 am
clutch slay. i changed it out and it was fine for a few days then it happen again. I found out the new rubber line that i put on for the clutch slay needed a little more torque. so then i bleed it again. it seems to do ok but nothing like before the old slay went bad. it still drops down a little from time to time. but never all the way to the floor. the main hard line coming from the master cylinder on the fire wall, runs under the car and ties into a square block. it has a few hard lines running off of it. can i take that block out of the system and run a solid line from the master cylinder straight to the clutch slay?
