:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Oct 09, 2003 3:52 am
If I understand this correctly... :
You assume your block hasn't been bored, and based on the original size, you bore it, and select the right grade...
The grades are found in the sticky thread on the main page, called "OEM Specs" or whatever...
Here's a cut and paste:
Cylinder Bore(inner diameter):grade1: 89.000-89.010mmgrade2: 89.010-89.020mmgrade3: 89.020-89.030mm
Later - Brian
And one thing to watch out for - The early 9.1:1 SOHC pistons may not have enough clearance...i.e. they may hit the head. Check the deck clearances to be sure.
The reason I point this out is that the one high compression KA I've read about used 9.1:1s milled down to achieve 11:1 - That's "Rownan"...
Later - Brian
