What to do!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Nathyne
Car: 1994 Skyline GTR
1983 Datsun 720 4x4 reg cab KA24E swap in the works
Okay so I started to fix the screwed on pieces of sheet metal that were covering a hole in my floor. Not too sure what to do with the mount though! I was thinking about just sticking a jack under the cab lifting it up a bit and cutting it then welding some flat iron on then drilling a hole in it and maybe using just a normal bolt and washer instead on top? the bolt was almost completely rusted through and snapped at the slightest turn. Here is a picture let me know some opinions!
Uploaded with ImageShack.us
Also forgot to say would of course cut the old rusted part off before I welded something on top.
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
How about putting a 1/4" piece of plate on there? Drill/burn/blow a hole for the bolt and prob solved :yesnod I'm ASSuming you have welder and torch wrench
After rereading your post, I belive we're thinking on the same field :facepalm:
Return to “Datsun 720”
