What should I have done...
weatherfox
Car: 2007 G35X
Just got a used 2007g35x with 49,000 miles on it. I want to bring it to a dealer and have them check what needs to be changed. However, does anyone have any recommendations?
The next oil change is due at 51,000k so I'll bring it in then. Is there a recommended service at 50k? Thanks :)
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
next big service is at 60k which includes the transmission getting flushed, belts if needed, radiator flush\cap if needed, rear diff and AWD diff service if neeed, induction cleaning (optional), cabin filter if needed, basically all the big dollar items...
basically every 30k is the main service, in between that its just oil changes, intake filters, tire rotations, brakes if needed, etc
kmckis1029
do not skip a transmission service, so if you asking what you should do, always do the transmission service...
$100+ now or thousands of dollars later...
weatherfox
Car: 2007 G35X
thanks kmckis, the 60k does sound expensive...do you recommend getting that done at infiniti? Or nissan?
SVTCOBRA
Car: 2018 Q60 AWD 2023 F150 4x4 5.0 FX4
I would go with the dealership that you trust the most with your car....
If that is a toss up, I would go with the cheaper of the two...probably Nissan.
I have my transmission's flushed at my local Nissan...for both reasons above. :biggrin:
audtatious
Here is the maintenance schedules for Infiniti G's:
http://www.infinitig37.com/maint-sched.html
weatherfox
Car: 2007 G35X
thanks guys...i was thinking of having them do new plugs and wires, air filter, oil change, tire rotation...only because i am not sure what the previous owner had done.
telcoman
weatherfox wrote:thanks guys...i was thinking of having them do new plugs and wires, air filter, oil change, tire rotation...only because i am not sure what the previous owner had done.
I changed my plugs at 105k. Probabily could have gotten another 5-10k miles out of them
Telcoman
SVTCOBRA
Agree with Telcoman
I changed plugs at 50K in two G's and believe it was too early in both cases, however I was checking for leaking valve covers (plug chambers) so I changed the plugs since I had to pull the coil paks.
kmckis1029
do the air filter your self, save your self about $65... its too easy of a job to let any shop do... unless its free lol
The air intake filter will cost about $20 at any auto parts store or dealer, the dealer will charge almost a full hours labor for a 10 minute job smh..
