what octane gas?
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
hey guys,
just want to know what octane gas you guys are using in you CA18's?im putting mine in either this week or next week so im just wondering what octane i should use. Thanks guys!
zmannz
Car: 89 s13 coupe- track car
92 s13 coupe- dd
turbo cars usually like the highest octane available. It all depends on your setup as to what you can get by with, but why risk the trouble? I use 93 all the time in all of my performance cars.
sjbsuperman1425
CA18DET
thats what i figured, just wanted to be sure Thanks!!
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
when it was a daily i used 93... now its got about 5 gal of 116 in it at all times.
Indecisive
Car: 1987 200sx Turbo
Is there that much difference between running 92 and running 94?
92 isn't that much cheaper per litre, but when you're getting at most 300kms a tank, every little bit helps :D
Or could you run 94 in the summer when ambient temps are higher, and 92 when temps are lower is switching a bad idea?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
Indecisive wrote:Is there that much difference between running 92 and running 94?
doesnt seem to be much difference between the US 91 and 93, but I always go for as high as I can get.
then again does canada use a different system of calculating octane numbers? I know that is always a challenge for me to figure out.
Indecisive
I definitely never felt any difference between the two...but more input is appreciated.
and Canada uses the same AKI rating system as the US.
float_6969
As others have said, I didn't see a difference in power between 91 and 93. I even tried resetting the ECU to see if it would add any more timing. IMHO I think the CA was designed around what is 91 octane for us. Anything over that probably isn't going to do anything for you unless you are having some sort of problem with knock.
DALAZ_68
Car: 90' 240sx CA18det
i always run 91 (highest common octane in SoCal) but i have run 101 once or twice...didnt feel any diff...im told u hav eot change up ur timing to actually feel any real diff of the octane...but i wouldnt know
Blackened
Car: 1994 200sx ca18det
DALAZ_68 wrote:i always run 91 (highest common octane in SoCal) but i have run 101 once or twice...didnt feel any diff...im told u hav eot change up ur timing to actually feel any real diff of the octane...but i wouldnt know
I use shell 100 octane of europe
