Hey guys, my name is Mike and I am new to the forum. I have been lurking for a few years to find information on a periodic project I am helping a friend with. I found this thread, and figured it was time to register.
Said project is an S13 RB25 swap. It has been running/driving for a few years now, but small changes have been made here and there when time has permitted. Just like any project!
The latest task is going to be rerouting the intercooler plumbing. In doing so, we plan to run an atmospheric bov and blow-through MAF. This is my first RB25, so I have had a lot of learning to do. However, it is certainly not my first turbo/maf project... so I planned to use a set up similar to the Ford builds I have done.
In my opinion, the Lightning MAF is old news. The hot new sensor to us Ford guys is what we refer to as the "Slot Sensor". It is a Hitachi made hot wire sensor with an integrated sample tube, providing an analog 0-5v output. The sensor is also commonly known around some of the forums as the "05+ sensor", as it was first seen in 2005 and up Mustangs and other model Ford vehicles.
The real beauty of this sensor is its mounting posibilites. Factory made housings are not needed, and the sensor can be mounted into any shape/size tube with a custom flange. Allthough, tube housing are also available in many diameters for those wanting to just clamp a unit in line and go.
The stock Ford unit is good to roughly 300whp mounted in a 3" tube in a blow through set up (5v @ 47Lb/Min). However, the aftermarket version made by PMAS (HPX sensor) is good to 650whp in the same 3" tube. Step up to a 4.5" tube and the HPX sensor can support upwards of 1000whp.
The stock Ford unit is the same sensor on all 2005 and newer Ford vehicles, so finding one in a junk yard is easy... and can usually be had for under $40. (I got my first one for free!)
The HPX sensor is a bit more expensive.. but very affordable compared to some other aftermarket sensors that require a specific housing!
http://www.vmptuning.com/store...nt=30Associated flanges and tubes can also be found on that site.(Also, I don't mean to sound like a salesman. I have nothing to do with VMPtuning or PMAS in any way... just giving info here.)
Anyway, the plan is to run the HPX sensor in blow though on this RB swap. I have had great results running it in blow through on my Ford vehicles, and I expect the same on the Nissan.
It seems like you guys are having a hard time finding transfer functions on some of the stock Ford sensors (Lightning 90mm, etc). You really need to poke around some of the Ford forums, that's where you will find your info. Here is a link with a few spread sheets of different for sensors:
http://rothfam.com/maf/tools/http://rothfam.com/maf/
If using the HPX slot style sensor, the transfer function get even easier. Just put your dimensions into this tool:
http://vmptuning.com/sct/HPX%20TOOL.xls
I'm not sure why the units are not noted... but they are kg/hr. Really not sure what units you JDM guys use, but incase you do not know the math, here is a great converter: http://www.translatorscafe.com...in%5D/ (Link is set default to convert kg/hr to lb/min... I use lb/min to tune, and you will notice most of the Ford transfer functions will also be given in lb/min.)
I will also post 90mm transfers for you guys in a separate post to keep clutter down on this post.
Hope this helps some of you! Happy to finally be a member! Tons and tons of great info on this forum.
Mike
Modified by LSV8mike at 6:07 AM 2/2/2010
