What MAF will do 1000whp?
jrhdohc
Car: R32 GTR
cool. why did you switch back?
Cjmartz2k
Car: Hunting for a '89 GTR now
Crappy performance at lower rpm. The MAF got real "confused" at part throttle transitions (lifting, rolling into WOT going up a hill in a higher gear at too low an rpm, etc) and it would go way rich. If we leaned out those specific spots tuning, it would lean pop in other types/areas of driving. It just didn't have the resolution down low. Now WOT in boost it working like a dream.
jrhdohc
Car: R32 GTR
i guess i'm confused. so your high hp MAF did or didn't work?
Cjmartz2k
It worked, it was just "touchy" and I got poor gas mileage. It's because we "made'' it at the shop. I daily drove it like that for a year or so. Some of the aftermarket ford ones are much better at dealing with that problem. I just didn't go that route and had a chance to go to a D-jetro for no money what so ever, so I jumped on it.
jrhdohc
Car: R32 GTR
ic... sounds like MAP might be the way to go.
BHFR-GTR
Car: 1993 s13
sorry it took a min to get back to you i have been out of town, but that pic came from my engine bay, that is a greddy dual maf intake i think it was like 250 bucks from sp engineerring they had one in stock when i called, it is set up for twin z32 mafs hope this helps
Beanstalk
Car: 89 240sx & 95 240sx
Cjmartz2k wrote:
First, REMOVE THAT HUGE a** PIC FROM YOUR SIG. Second, do you understand the fact the power FC's come in both MAP and MAF flavors? Simply suggesting the most well known aftermarket ecu as a soultion to a problem where people can't use the Z32 MAF which supports over 500rwhp because it's not big enough probably isn't going to be very helpful. Somebody talking about making 1000hp isn't going to be doing it with a SAFC. I'd bet he already has a MAF style Power FC and wants to stick with it since they are so expensive. I'm sure he has his reasons for not going D-jetro (MAP) power fc or something like a haltec or F-con V-pro.
Now hush, the grown-ups are talking.
...LMAO thanks for the advise but I do have the PFC .... The only problem is they dont make the d-jetro for the 25 .... and you hear from the pnut gallery that it's coming out soon but let me be the first to say it. It's not.... apexi has abandoned it the same way they discontinued the pfc for the 25 I will keep it as long as i can make 800whp (no nitrous)
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
i was interested in doing this on my rb, i found a svt maf that was rated to 1000 plus but they told me to take a hike b/c im a import
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Who told you that?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
jrhdohc wrote:
2JZ has both MAF and MAP stock. Lower power (stock) MAF is Load and MAP is boost sensor. Medium power they disable the stock MAF and run MAP for Load. I think it's good for around 1.5 bar. High power a huge single turbo with aftermarket 3-4 bar sensor.
Not quite hotshot. You make some of the funniest posts ever.
Cjmartz2k
SullivanRacing06 wrote:i was interested in doing this on my rb, i found a svt maf that was rated to 1000 plus but they told me to take a hike b/c im a import
Shouldn't need there help with anything. I can't tune, but from what I've seen my tuner buddy (Stec) back in Okinawa do, it was just a matter of figuring out the MAF voltage curve just like any 0-5v MAF. Also, you'll need to figure out what pin does what to wire it in, but there should only be a few pins to figure out (5v, ground, signal, etc.).
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
DrifterProdigy85 wrote:Who told you that?
SCT has told me that same thing. Sad how domestic loyalty takes precendence over running a good business...
Darius
Yes, that is all you need to do and I know it will be cake to do with the PFC. Repinning/wiring will be easy too. The hard part is getting the voltage/air flow relationship correct. This winter I want to buy one of their large 4-inch MAFs, hook it up to a flow bench and figure out the voltage for given flows. I'll post the info all over the internet for imports just to piss them off
Cjmartz2k
DO IT!!!
Seriously though, I'm no tuning expert (or even novice), but Stec figured mine out as we drove down the road. He made it idle, then had me step on the gas (while parked) and get it to "X" rpm higher and higher at about 500rpm intervals and rescaled the map doing that up to about 5k rpm to make it drivable. Then we went out and tuned, and he kept rescaling the curve. He only tweaked the fuel map when we were finishing up the WOT tuning, and his tunes kick a**.
gawdzilla
Car: none
the thought of this crossed my mind back before i went d-jetro.
in theory you could build an intake pipe with the original MAF and the SCT MAF in series, and log the voltages of both while driving around such that you have some comparable voltage numbers vs. airflow to extrapolate a best guess curve for the new maf. that would help, considering the PFC calculates airflow in a weird unit anyway.
Cjmartz2k
The D-jetro does it in a weird way, but MAF is pretty straight forward.
DrifterProdigy85
Lol. I contacted SCT back when i had my SR and the guy i talked to was more than helpful to me. I told him what i had and the power i was looking for and he told me what i needed and then we started talking about his S13 he used to have. lol. I was asking him all kinds of questions of Blow Through setups and stuff like that. You must of just got someone having a bad day.
Darius
haha well call that dude back and get the info out of him.
s14_sport
I have been running my Ford SVT MAF for about a year now. But I am using a tuned ECU from Jim Wolf Tech which they claim is capable of 700HP with the right turbo. The ECU is actually from a 91-94 Maxima that they flash for use with the RB.
It a great tune that I'm happy with just alittle rich at idle. So had to use S-AFC to clean it up a bit.
My new turbo setup I wanted to try and clean up the engine bay so I set it up as a blow though MAF. I'm not sure how well this is going to work with the JWT ECU and the S-AFC, but, I also have a PowerFC that I will try as backup. I have found a rough voltage map online for the SVT Maf so I'll give it a shot.
DrifterProdigy85
Darius wrote:haha well call that dude back and get the info out of him.
His name is Sean Jakober. Email is [email protected]. Last i talked to him was back in august i think. With the economy its hard to say if he still works there. An email would be worth a shot though.
Darius
Cool! Thanks. I'm on it like Tiger Woods.
Madgoal1
Car: 01 330ci, 92 240sx coupe
you have mail
Darius wrote:Cool! Thanks. I'm on it like Tiger Woods.
Darius
Thanks Sean! It is exactly the information that I was looking for! I will post it a little later tonight
I just got to looking at the FC datalogit inputs and, no surprise, the PFC values for the MAF voltage vs. air flow are not intuitive. Does anyone know off-hand what the following "units" that Apexi uses are?
RB25DET MAF ____________________(0 to 5.12V) = (0 to 4423) unitsRB25DET MAF w/Apexi Power intake __(0 to 5.12V) = (0 to 4647) unitsZ32 MAF ________________________(0 to 5.12V) = (0 to 7546) unitsQ45 MAF ________________________(0 to 5.12V) = (0 to 6683) units"Custom" MAF ____________________(0 to 5.12V) = (0 to 10860) units
meet07
Car: 89 180sx rb25det
what kind of blow through tube are you using?? I found this that might help everyone if they dont allready know.....
Seems that you can bolt the lightning maf up to this blow through tube that eliminates the maf blowing up. might be a great alternative when using something like nistune..
link:http://www.atomicperformance.c....html
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
why buy the tube when u can just buy the adapter to put on your own tube?http://www.vmptuning.com/store...&pg=1
Bernard
http://www.abacoperformance.com/products.htm
You could accomplish the same thing with dual z32 mafs or a single maf and a bypass pipe the same size . Either way it sounds like a fun project.
Darius
Fellas. The easy part is finding a MAF or creating a MAF setup for measuring the increase in air flow.
The tricky part of this upgrade is properly telling the ECU how to interpret the voltage signal from the larger MAF sensor.
I have searched on the datalogit usergroup and have found no concrete answer on what units the powerFC uses for airflow units for the MAF. The internet is not turning anything up either. I e-mailed Ali at Apexi-usa but he apparently does not work for them anymore. I think I am just going to try contacting Apexi-usa to get a solid answer to this question tomorrow.
What air flow units are used in other EMS's?
scarboroughdub
The main issue is maf Linearization table, Once you can properly translate the airflow versus voltage. then all you really have to do is retune for the change in Theoretical pulse width.
Rb26 Maf translation
Lightning Maf translation
<...we interrupt this kickass thread for a message from the management...>
Best thread going right now... Some great expertise being passed along. You guys are making my head hurt!
...any chance someone might want to compile the information herein into an article? (I'm not so sure I could do it justice.) If so, touch base with me via email.
Carry on, gents.
<...we now return you to our regularly scheduled programming...>
meet07
Yellow4g63 wrote:why buy the tube when u can just buy the adapter to put on your own tube?http://www.vmptuning.com/store...&pg=1
Just what I was looking for. Saw it in one of your builds...THANKS!!!!!
