What MAF will do 1000whp?
PFL
Btw your maf is done and on its way back to you.. bad news it was an old 80mm.. not so super but it flows a lot and will work fine.. you will need to get a connector for maf harness off of a 96-04 ford to wire it in.. you will also need to get a filter online for a PRO-M 80mm I think UPR products has them pretty cheap.
240z4u
Car: '95 Nissan 240SX
It came with harness connectors and the appropriate filter thankfully. I'll update after I get further along. My IAC cleanup/replacement got out of control and now my intake manifold is sitting on my workbench. lol
Thank you for the ridiculously fast turnaround time.
240z4u
You win the prize for turnaround time. I assume I just leave my ECU mapped for the Z32 ECU and tune it with this sensor correct? Thanks again.
240z4u
Precision Flow Labs to the rescue. Knowing that the PFC isn't capped by a z32 sensor anymore is awesome. The guys were able to recalibrate this PMAS mustang maf setup for me to offer more range while maintaining the curve of a z32 sensor. I am running draw through obviously. I will be building an intake to accommodate it soon!
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I wish I knew about them before I sold my Nistune and got my AEM lol. Will it flow more than the Z32? or do you have to change the maf curve in the PFC to make it do more?
240z4u
Flows more than a Z32 but uses the same shape curve. This requires a re-tune job BUT doesn't require building a totally custom MAF table.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
getting excited over here......mine is nearly maxed out as well....waiting paitiently for good results...
240z4u
I should be able to get it tuned/figured out when it gets a bit nicer out. I hate waiting too!
Largekid
Car: '96 RB S14 SE, '04 LS6 CTS-V
bump, how did this turn out?
240z4u
I ended up taking a lot of my car apart and redoing a bunch of stuff so I could actually fit this in my engine bay. I should have it done and running next week.
