Post by Akihisa » https://forums.nicoclub.com/akihisa-u31859.html Tue Oct 04, 2005 4:13 pm
Post by Coldspawn » https://forums.nicoclub.com/coldspawn-u30190.html Tue Oct 04, 2005 4:37 pm
That is correct, below .5v closed, around 4.5 volts open. It is the same as hondas.Akihisa wrote:I am putting a KAe throttle body on my CA and I checked voltage at idle and it is only .441vdc. at WOT it is 4.4xx vdc.
Post by Akihisa » https://forums.nicoclub.com/akihisa-u31859.html Tue Oct 04, 2005 4:40 pm
Post by Coldspawn » https://forums.nicoclub.com/coldspawn-u30190.html Tue Oct 04, 2005 4:43 pm
Yep, they are around 1v closed throttle.Akihisa wrote:Thanks. My ford and chevy are slightly higher.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
