mdmellott »
https://forums.nicoclub.com/mdmellott-u292054.html
Thu May 12, 2022 7:44 pm
750rpm (+ or - 50) in P or N is what you should be getting if all is well with your sensors (MAF, IAT, ECT, O2), in addition to the TPS, its proper adjustment, and the IACV, along with its learned adjustment. 700rpm is at the low end, obviously. Dropping to 600rpm is too low, while in P or N. While in D at idle, your engine speed will drop a bit (50 - 100). If it's stalling while idling in drive, check the sensors, adjustments, and gas quality. Your '01 QX4 is very much the same as my '02 Pathfinder. Premium is recommended.
Check your TPS and its adjustment first and then go through the IACV relearn procedure. If all else is well, that will likely get your idle where it needs to be.
