I recently took my Z to Intec Racing, a shop out in Kent, WA and got a new Haltech Platinum Series Z32 ECU so I can switch from MAF to MAP, a new Greddy Profec boost controller so I can get the car finally tuned. After all of the installation, the loaded up the Haltech software and saw that the channel for the fuel pump was getting signal, but wasntvreading any numbers because the fuel pump was dead. They guys at Intec tested the harness as well as the relay and determined that the fuel pump was indeed dead. We got a base map loaded and the owner, Lawrence (cool guy btw), says the only thing I need to do to get the car on the road is replace the fuel pump.
What fuel pumps are you guys running. I'm torn between a Walbro 255 and a DeatschWorks DW2000. They're similarly priced and have the same output, but I'm not sure which one I want. Let me know what you guys are running so I can get a better idea of what's already working for the Masters of the Z Universe.
https://youtu.be/QIYGy4e76fU
