What does mean P0141 Nissan Tiida
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
hanialbarni
Car: Nissan Tiida
Hello
I am planning to purchase Nissan Tiida used car model 2013, Mileage is 45,000.
The car is clean but the problem there is one small problem as he said seller which he check the car using computer it shows P0141 error code.
So what does mean P0141, Is it big problem or small ? How much it cost to fix ? Is it easy job to fix or difficult job to fix ?
And Finally shall I buy the car or shall not ?
Also if someone could show the exact location of P0141 error in car ?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
P0141 Nissan - Rear Sensor Heater Circuit Malfunction Bank 1 Sensor 2
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
Tech notes:
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem
Read more: http://engine-codes.com/p0141_nissan.html#ixzz3gAk8n8GD
hanialbarni
Car: Nissan Tiida
Hi Rogue One
Thanks for reply, where does O2 Sensor 1 is located ? and how much does it cost to replace it ? What is the cost of this ?
Rogue One
2022 Honda Pilot SE
What model year do you have? In the US the Tiida is known as the Versa.
hanialbarni
Car: Nissan Tiida
Hi Rogue
I have model 2013, Yes I know but because I could not find in the forum category of Nissan Tiida so I checked alternative name for the car such as Versa in USA.
How much does it cost this one ?
Rogue One
2022 Honda Pilot SE
http://www.autopartswarehouse.com/sku/D ... 44534.html
Denso NP2344534 Oxygen Sensor - 4-wire, Direct Fit
Part Number: NP2344534 Manufacturer Number: 234-4534
$139.33
Return to “Versa Technical Discussions”
