I have to respect your opinion because it made me think it over again. I should do things in order. There are a bunch of cool mods I could do for the same price. I'd rather have a performing truck anyhow.Desert Rat wrote:My two cents worth...I'm not a fan. I like the cleaner more subdued look.
$151 doesn't sound like a bad price tho.
Wait what performance mods are there out there for these things..ive looked everywhereReverend D wrote:
Or make stuff, like I'm doing. From the Megasquirt to the piece together a part at a time turbo kit, to a coil sprung (in planning) rear end, you have to sometimes think outside of the catalog and do it yourself.Reverend D wrote:You are looking in the wrong places. Most mods for these trucks don't come from catalogs. Two things that come to mind in that price range give or take a little... 1) Get a used cam re-ground to give the engine some more pep. Or 2) Rear suspension upgrades including putting it towards a rear sway bar kit. Stuff like that.
Well, I was asking kib, but I still say sticking with the old drag racer's trick, but in the opposite direction. On our 4 cylinders, installing 6 cylinder shocks and sway-bars are a great budget way to stiffen the front end.Reverend D wrote:Mines a 4.
i have the 4 cylinder with NO ps which really sucks on complete stops...and im having springs from a pathfinder removed from a local pick and pull to see if they will fit and theres a nissan guy down the road that has at least 4 junker hardbodys with ps still on them so im gonna try to snag oneDrift21_Hardslider wrote:You have a 4 or 6 cylinder?
only one comment here....4x4 centerlinks are junk. they'll create more steering slop with that dogbone design.Drift21_Hardslider wrote:
Want adjustability in the shocks, but don't want to blow a fortune, check out your local short track shop! I found some Pro Shocks SS Series 3 position shocks at Stock Car Products in Richmond, VA. At only $75 a shock, this is a great option to get started on an adjustable suspension. http://www.stockcarproducts.com/pshocks5.htm
Want more steering angle? I'm going to experiment with using a 4WD center link. My theory is that it will create more angle just like adding spacers on a rack-and-pinion setup.
One other thing, we have a slight advantage on front end adjustability, because we have torsion bars not only can we adjust height right out of the box, but pre-load as well! We don't need to buy a $1-2,000 suspension setup to gain the advantage a 240SX guy has to. Don't knock the torsion bars yet!
What would you recommend in it's place besides going to rack and pinion? Maybe a Toyota 4WD center link? I would love to make a custom one, but I haven't found the place all these drift guys are getting their ball sockets from.Desert Rat wrote:
