I've been chasing a poor idle and less than 100 percent performance for months now.
After doing all the usual stuff (MAF, BG44, SeaFoam, IAC, connectors, etc.), I replaced three injectors that had high resistance from 18-35 ohms.
Maybe a little better performance but still lumpy idle. ECU code is 55.
Replaced the Bosch Platinums with the correct NGK plugs.
You can view the plugs here:
http://mysite.verizon.net/vzeri3wo/
CLICK ON "MORE PHOTOS"
I would appreciate input reading them. I am focusing on plugs 2 and 4 that seem to show poor ignition and/or too rich mixture.
Injectors bad even though resistance is ok?Coil or ignitor transistor are weak/bad?Other?
Thanks
Don
Modified by daegrigg at 6:53 AM 4/22/2006
