what did the SE's come with?
GtrSol
I'm about to buy a 91' 240sx fastback SE. What did the SE package come with?
thanks
nametakennow
Car: '06 MINI Cooper S
Isn't this in the FAQ sticky? Alloy wheels, 5 lug right? LSD, uh... nothing else much, I think...
GtrSol
I didn't think he s13's had a 5 lug option, but yes i found the sticky thanks.
nametakennow
It appears the diffences aren't in the sticky. That might be a good addition...
GtrSol
Yeah, i just noticed that too. Anybody? SE s13? what did it come with?
dennis
i have an s13 se coupe i dont know if the hatchback is different, but anyway i think the only difference was all power, and a different sound system, i remember i found a site a while ago with all the specs of each model but cant find it, ill try to find it, if i do ill post it.
dennis
GtrSol
from what I've picked up the S13 Fastback SE came with, pw, pl, sunroof, alloy wheels, cruise control, rear spoiler, and something to do with the steering, i can't remember the name of it now. Oh, and a rear windshield wiper.
I still don't think the 89-94 s13's came with a 5 lug option even with the SE. I've seen the SE wheels on the S13 and they always look to be 4 lug.
Is this all correct?
Megaseth
Car: 2002 Pathfinder SE
Yes, the SE models had 4 lug alloys. the base models had steel wheels with hub caps. the steering is HICAS, and thats not what the SE came with standard, it was an option.
drift_R
Car: imports
i thought that some of the features on the SE where HICAS... HUD... and I thought LSD? maybe I have been misinformed, but that's what I thought..
Cyberkreig
Car: 1993 Nissan 240SX SR
i have an SE hatch. power everythin, Sunroof, alloywheels, rear wiper(was that standard for the others?). HUD was an option or part of a package, HICAS was an option(only on the SE i think), I think that VLSD was only on HICAS, but people argue about that...
MaineExport
Car: 95 Nissan 240SX FAL fans AEM intake Hot Shot header Apexi N1 dual Exhaust VLSD ABS NX 50 shot
I have an options package list for 95 US 240sx models... right from the dealer. I'll gladly write it up and have it posted in the FAQ... which mod should I send it to?
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
I thought the S13's came with a moonroof and no sunroof
Cyberkreig
what makes them different?
MrFox
LSD comes with hicas and anitlock brakes option
hicas obviously has different steering and suspension bits
HUDs were only in SE coupes
i think the LE and the SE also have fog lights where as the base just has little plastic grills where the light goes.
also try Edmunds, select trim then select Standard Features from the left menu. (though my car does not have power mirrors like it said it does)
http://www.edmunds.com/used/19...ssan*
cheers
GtrSol
on the 89-91 SE's the sunroof...did it just vent open or is it one that opens all the way out like mine did on my rx7?
Megaseth
The sunroof just pops upand. the fog lights were on the canadian versions. they were daytime running lights. they actually look pretty good.
dennis
only the coupes have the moonroof that slide all the way back, probly because the hatch theres not enough room in the roof cause the rear window gets in the way.
drift_R
Car: imports
i have heard that HICAS is something to steer clear of ( no pun intended)... is that true? i myself am about to buy a 240 coupe and am wondering if i should buy the SE model or not... I will be swapping the engine for the SR right away, so will it even matter which trim level I get? thanks...
mike:help
killjoy
Oh my gosh! Se's when talking about the s13 coupe did not have hicas or LSD. The only car that you can get HICAS and LSD on is a s13 fastback SE and its an option. But you can't get lsd without hicas so that sucks. You are better to buy a s13 coupe se and swap a lsd diff in it.
lilaznvietboi
Car: computers
the sunroof just vent open. They could made the sunroof power on the SE H/B, since everything else was power.
Drift
Oddly, my 92 240 SE w/ HICAS does not have power locks, they are manual. :-( But other then that alloys, power windows, moonroof, LSD (don't know if VLSD), and power mirrors.
