What clutch to go with?
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
I hadn't read much on them, just figured there would be newer/possibly better clutches for the 350Z
moneymike
Car: 1991 nissan d21 hardbody
http://www.frsport.com/ACT-NS3-XTG6-6-P ... 15409.html
s13 drifter posted that one up.
would be pretty much perfect for my set up
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
If both of them spline up (Cause Im not 100% sure) with your input shaft then running either of the two will give you some pricing options. As far as Z clutch on a RB wheel it really doesnt matter cause both of them are the same clutches. Ive installed a Z-tt clutch (Spec stg3+) on a RB Fidanza (I think) lightweight wheel on an RB25. Again, just opens options when you can cross stuff over, my $.02.
moneymike
from what i read online the ka rb and z32 and z33 have the same 24 splines
s13drifter88
If they're the same then it will work and if it fits your setup perfectly then you know which one to order
