What brown has done for me...
8ggalant
Car: nissan cefiro
....in the past month or sohopefully all will be installed shortly...i needa buy a clutch tho and im gonna do it all at once
ssac ca18det manny, o2dump/turbo extention, dp+testpipe combined,s14bb, cams arent tomei they are colt cams (dee's regrind-and no not the "mystery" ones off ebay)
Nowhere
Car: Suzuki x-90, samurai
Might want to have a piece of flex pipe installed on the long pipe.. Some SS braid..
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Nowhere wrote:Might want to have a piece of flex pipe installed on the long pipe.. Some SS braid..
That's only a myth. If you use the transmission brace on the downpipe you should be fine. If it were a transverse motor where the motor rocked front to back, then a flex-pipe would make sense. But not on a longitudanal where the motor only shifts side to side.
8ggalant
Car: nissan cefiro
has anyone here used or know of anyone who has used this setup ...im wondering about the dp/testpipe fitment....i guess we'll see wont we lol
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
Didnt know you were on here ! this is slw240sx from OD.
only experiance i have had with the Long downpipe version was with stock manifold and o2housing it put it straight into the frame rail. might actually fit with with the SS O2 and manifold.
float_6969
I'm running an SSAC mani, T28, and the Fly'n Dumpipe (O2 and downpipe, all in one). It fits like it's stock. You can BARELY see my downpipe past the frame rail and it's miles away from touching it.
8ggalant
Car: nissan cefiro
well see...i also noticed while lookin at my ssac sr dump and ca dump that the ca dump is slightly shorter in height...tha may have a little to do w/ why sr pipes sit low also (tho im sure its mor motor angle and turbine placement)
