what bolts for j30?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
So I can't find bolts anywhere in town except 100mm long and has about 2 inches of thread. Is that too long? I gotta get this j30 in my car. Cuz im dieing to get my one piece driveline in that I got for it.
krash
Which bolts are you talking about?
compactfean
daily
The 2 bolts in the front of the diff. Where the rubber bushings are.
compactfean
daily
Anyone?
s13sickboi
Car: 1997 Nissan Hardbody XE
Use your stock ones? you know you need to run solid bushings so your rear cover doesnt crack right? if you remove the rubber bushings and put some filler like quicksteel in the holes you can use your stock diff bolts.
Did it on my car so I gurantee it :biggrin:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
S14 or J30 bolts
compactfean
daily
s13sickboi wrote:Use your stock ones? you know you need to run solid bushings so your rear cover doesnt crack right? if you remove the rubber bushings and put some filler like quicksteel in the holes you can use your stock diff bolts.
Dude I never even thought about that or thought that could be strong enough. So did you fill the whole thing and drill it out? How did you center the holes? I have read up on this but never heard about the cover cracking. But totally makes sense. Fr sport has a bushing and bolt kit but I just can't justify spending 90 bucks. Im def interested in your setup. I know jb quick wont work very well so maybe the quicksteel or industrial jb weld?
sabretooth91
Car: 1989 240SX coupe
I found some bolts that are 90mm long on MCMASTER.com. (they also have 80mm long)
M12 x 125mm right? You have to order 5 of them (have to buy bags) or more. I think the bolts you actually need are 85 mm long. Since I have 5 of them, I'll try it with the washer and the bushing, and try cutting a bolt down if I have to, or adding another washer. They're $15.something for 5 of them off this website.
s13sickboi
apologize for late reply...
What I did basicly is cram some quicksteel into the old bushing holes after removing the old ones, eyeballing it so it looks centered. JUST MAKE SURE THE BOLTS WILL GO THOUGH!! If not tho no biggie you can drill them out if you have to.
Next get the biggest a$$ fender washers you can fine at home depot, recommend gettin 4 beacuse they arent the sturdiest things ever, but they work. I forget what size I got but they were HUGE!
Now you can just bolt it up there (if everything lines up of course) and your good to go! Been running mine since Feb. '10 no issues :bigthumb:
Good luck! Let us know how it goes and if I need to post pics of mine... no biggie for me to if you need it
compactfean
daily
So did you. Use the metal. Insert part? Or just burn all of it out and quicksteel the whole thing? Im doing this this weekend. You got. Me stoked! Can't wait to use my one piece and get rid of my welded.
sabretooth91
I vote for pics please! I've a very visual person.
s13sickboi
Nahh I completely knocked out the bushing and cut the ring out... The rubber was so old on mine they just practically fell out lol
Haha glad your stoked! I was when I did my first little 'mod' (the diff) :chuckle:
EDIT 1: Pics coming!
EDIT 2: Pic whore time!! :naughty:
lulz^ forgot it aint metric...
^there! :chuckle:
And just cause im a pic whore, this is my $hitty work environment
Washer size is 1/2" x 1-1/2". two of them are pretty sturdy actually, found out they're 1/16" thick
Also I sanded the Quicksteel flush with the metal on both sides.
sabretooth91
Thanks for that. I'm putting in my diff from a 300ZX (non-turbo) soon. I just need to find some frecking output flanges! When I ask salvage yards for the LSD output flanges from a 95-96 Infinity J30, they act like I just asked them to slay a dragon!
compactfean
daily
^ right! I got my diff from Rancho Cordova and specificly told the 95-96 and the sent me a early year j30 diff. I told them to make it right send me the output flanges. From a 95-96. Two months later I finally got them to. Send me 93 axles cuz they didn't have output flanges. God if only people would listen. At least they made it right.
compactfean
daily
s13sickboi wrote:Nahh I completely knocked out the bushing and cut the ring out... The rubber was so old on mine they just practically fell out lol
EDIT #1: Ill take some pics and update this post.
Well not my first little mod (mine is welded right nowand is just to much for dd) so cut, clean, fill, let set, drill, and install with double washers each side?
s13sickboi
Yeah, well the j30 was one of the first things I did to my 40.
compactfean wrote: so cut, clean, fill, let set, drill, and install with double washers each side?
Yup! hav fun wid it! :biggrin:
sabretooth91
compactfean wrote:^ right! I got my diff from Rancho Cordova and specificly told the 95-96 and the sent me a early year j30 diff. I told them to make it right send me the output flanges. From a 95-96. Two months later I finally got them to. Send me 93 axles cuz they didn't have output flanges. God if only people would listen. At least they made it right.
Yeah, that's exactly what I'm worried will happen. I'm going to try to find a local place so I can see the part before I pay. Good luck, right?
sabretooth91
Awesome pics! Thanks! I can "see" it now! I've never worked with quicksteel before. Could you put up a quick "how-to" and where to get it? Thanks :D
compactfean
daily
I'm set for the weekend! I just found a set of corbeau lg1 seers with brackets on Cl for 200 bucks! Wwoo woot ! That and getting rid of my welded ....super drivable.
sabretooth91
compactfean wrote:I'm set for the weekend! I just found a set of corbeau lg1 seers with brackets on Cl for 200 bucks! Wwoo woot ! That and getting rid of my welded ....super drivable.
woot woot! Have fun with that! May the craigslist gods smile upon your transaction. (and NOT curse you!)
s13sickboi
How did it go? :)
compactfean
daily
i
s13sickboi wrote:How did it go? :)
I had just enough time to get my seats and that was it. I Had my son this weekend and taking care of my 3 week old daughter didn't really have a chance. Im gonna get them filled and drilled today. I already got the quiksteel, just neef the washers.
