What are my options for 2002 front q45 replacement struts
hotlicksexhaust
The struts on my 02 q45 premium are making a tapping/clunking noise every time I go over a bump so I am guessing with 115k miles ther are due t be replaced. What are my options? Thanks
Q45man1
Car: 2002 Q45, 1994 Q45
There's not a lot of aftermarket options but stick with OEM shocks/struts.Replace the bushings too. Go and get it from our sponsor and they're having additional 5% off this month. http://www.infinitipartsusa.com.
longlivetitus
Car: 2002 Infiniti Q45 Sport
2007 Infiniti FX45
Hotlick!
Before you change out your struts and stuff, toss her on a lift and check to see if the 'bar' next to the sway bar is hitting the exhaust.
I had the same issue and it turned out that this bar next to the sway bar was hitting my exhaust. Use your weight and pull it down--done! No more noise going over any bumps!
If not, time for a strut & bushing replacement.Cheers!
Longlivetitus
seldomseen
Car: '12 Nissan Altima Coupe SR 3.5
'15 Lexus GS350 F Sport
Make sure the noise isn't from your end links first. If it is the shocks...get them from http://www.infinitipartsusa.com or ask your local dealership to match the price.
Q45tech
OEM shocks wear to 1/2 stiffness by 4 years or 60,000 miles no ifs or ands about it!
Waiting 8 years and 115k just shows your vehicular insensitivity to as new feel and performance, but most drivers are numb anyway.
hotlicksexhaust
So you are saying that after 60,000 miles no matter what they need replaced?
mcrews
Car: 2002 Q45 Sport
hotlicksexhaust wrote:So you are saying that after 60,000 miles no matter what they need replaced?
unless the car never ran over a pot hole or bump in the road....yep.I went to 80k when I replaced the 4 corners.
raven69david
Any improvments to aftermarket struts for our vehicles? My front struts are clunking when going over speed bumps so not sure if it's the entire shock that needs to be replaced or just parts. Anyone?
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
In my search on options for my 97' I ran into B/C Racing coilover options for your car
https://coiloverdepot.com/products/02-0 ... EBEALw_wcB
make sure to buy "with spindle" or you have to take them off your old strut. The plus is the car will sit a little lower (if you chose to) and it will transform you car into an "M" version of the car, it will handle MUCH MUCH better. BUT, the car will ride much stiffer, trade off for sure. These can be rebuilt too so if your going to keep your car for another 100k you can put new inserts into them later on...that is your single other option.
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
https://www.amayama.com/en
^^ I do not have any affiliation with them. Dont want to offend anyone. Given this unbelieveable world we live in now.
54302-AR126 front right 460$
54303-AR126 front left 460$
56210-AR026 230$
56210-AR029 230$
Doesnt say left or right for these
1380$ plus shipping. Would say 200$ shipping. 1580$ that's just the struts and boots let alone the hats and other odds and ends. Buy all 4 at once they will give you atleast 10% unless your haggling skills are superior.
Aftermarket coilovers... if you want that route. But they dont last nearly as long
BadQ45t
I wouldn't say that, BC inserts last at least 60k minimum, i put 30k on mine and they were still as good as new. But the inserts are much cheaper than another 1300 and less labor. But they will make the car ride stiff for sure.
BCC93QT
1995 Infiniti Q45
I stand corrected. I dont have experience on this model Q. But have experience with other aftermarket coils on other vehicles. It all really depends on the driver and which product. Comes down to pick and choose
raven69david
BCC93QT wrote:
Tue Jun 23, 2020 11:30 am
56210-AR026 230$
56210-AR029 230$
Thank you for the suggestion. If the car sat just a tad lower that would be a bonus.
BCC93QT
1995 Infiniti Q45
Dddddddont cut the springs please
raven69david
BCC93QT wrote:
Tue Jun 23, 2020 3:21 pm
Naw i meant if it sat lower than stock, after switching to coilers, that would be nice. I wouldn't cut the springs although back in my Mustang/Cobra days a lot of guys would cut the stock springs to lower the car instead of purchasing a lowering kit. :wtf2:
