joshuas13 »
https://forums.nicoclub.com/joshuas13-u176440.html
Sat Jan 22, 2011 11:12 am
I can't seem to figure out what is causing my alignment to shift. Any help would be appreciated. The alignment will shift around almost every time I make a sharp turn like parking. I have replaced the following: steering rack, tie rod ends, LCAs, strut mounts, energy suspension bushings, and tied the tension rod brackets together. The previous owner had adjustabe tension rods, kyb agx, ground control coilovers. Replacing these items have cleared up the front suspenion emensly, but have not fixed the shifts. The car is on Z32 rims with a spacer. I cant feel or see any movement. Any ideas?
