RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Mon Sep 22, 2008 5:37 pm
So I sprayed my engine bay/ engine off with water the other day with the coil pack cover on, drove it that night....no problem. The car sat the whole next day until the afternoon. When I went out and cranked it, it idled really really rough. I turned it off.....and took off the coil pack cover. The whole underside of the cover was soaked with condensation along with the coil packs....which I assume the water couldn't evaporate from the heat with the cover on. I disconnected each coil pack connector and sprayed them with that "air in a can" stuff, plugged them all back, fired it up, and it was back to normal idling. It sat overnight, and the next morning, I went out and fired it up, and it rough idled again.......about 10 mins later it smoothed back out back to normal. I left and went on a 350 mile road trip...and during that trip anything over 12-13psi of boost, it would hesitate.....wot or not, and in any gear.Should I dissconnect the connectors and let them air dry for a couple of days...or maybe pull the the coil packs out and pull the boots off or did I possibly do some permanant damage?
