Weird squeeking noise
weatherfox
Car: 2007 G35X
In the morning when I drive my car to work (colder weather lately) at around 62-68mph there is this odd squeeking noise that I cannot pinpoint. Its definately in front of me like dashboard/windsheild area. Its extremely annoying and can even be heard over the stereo. Its an 07 g35x, does anyone know what this is and if there is a fix? Thanks!
Kendahl
Car: 2008 G37S, Blue Slate, Premium, Navigation
I have experienced noises from the instrument cluster that are triggered by rough roads. The first instance, two years ago, was a jingling sound as if something was loose inside the cluster. The repair procedure, covered by warranty, was to lubricate the mounting point for the cluster. Now, I have a sharp knock under the same circumstances. The warranty expires next month so I need to have it fixed pretty soon.
weatherfox
Car: 2007 G35X
Yea its annoying. I can't pinpoint it but I will check the cluster tomorrow on the way to work. Should be cold enough in the morning for it to show itself again. Thanks for the hint!
weatherfox
Car: 2007 G35X
You were right Kendahl. As soon as I heard the sound this morning I pushed my hand against the cluster cover and the sound stopped. So my question to you is: Is there a part number? Or a is this a known problem that is already in the dealers computers?
I may just drip a little WD40 in the corners to see of that helps.
