JKL1031 »
https://forums.nicoclub.com/jkl1031-u171458.html
Fri Dec 31, 2010 4:34 pm
My problem:
-it is not air, the water pump, the radiator, fan clutch
I can drive the car hours before if overheats. sometimes only minutes. When it overheats, its totally at random, and continues to do it again shortly after restartup.
Without the thermostat in, it runs fine, engine will not heat up depending on ambient temp.
The engine pulls strong and is sound.
The car is warming up very fast from cold start.
No beading or intermix on the oil stick.
Could the headgasket be on its way out, or not properly sealed and sucking air in whenever it feels, or the head be bad? Again the engine runs strong and sound. thermostat has been put in and bled before by myself a pro.
