weeeeee. ordered my pistons wedensday, they're here today
f s t caz
Car: VG30ET D21 Extended Cab Pickup
very pleased with my experience w/ race engineering.. Pretty quick about responding to emails and transactions are very quick. and they gave me free stickers and a catalog.
total after shipping for rings and pistons was $548.63
Modified by f s t caz at 1:58 PM 10/15/2004
nocwage
Are those oversized or are they just straight replacements (except forged) ?
float_6969
Hey, I saw that ARP box, where did you get them from, and did they fit?
biosehnsucht
If you look closely you can make out the bore diameter on the spec sheet is "3.267", which is 83mm. They're stock replacements (hence why he got them so fast - they really DO stock them )
float_6969
Those guys over there rule....
f s t caz
nocwage wrote:Are those oversized or are they just straight replacements (except forged) ?
83.5mm pistons (0.5mm over)
f s t caz
float_6969 wrote:Hey, I saw that ARP box, where did you get them from, and did they fit?
no, those are the opel vauxhall studs from ebay.
f s t caz
biosehnsucht wrote:If you look closely you can make out the bore diameter on the spec sheet is "3.267", which is 83mm. They're stock replacements (hence why he got them so fast - they really DO stock them )
Race Engineering stocks both stock (83mm) and 83.5mm pistons. If you look again, you'll see "bore diameter : 3.287" which is 83.4898mm ('s a 8, not a 6)
biosehnsucht
Gah! Oh well, I just figured for 83 and it looked like it so I didn't try figuring for 83.5 to notice the similarity
boost_boy
Congrats on the purchase of the CP pistons! Why did you chose the the 83.5mm slugs? I chose the 83mm because I had no bore damage after 3 years of hard-core abuse. Anyways, good luck on your rebuild.
Dee
f s t caz
boost_boy wrote:Congrats on the purchase of the CP pistons! Why did you chose the the 83.5mm slugs? I chose the 83mm because I had no bore damage after 3 years of hard-core abuse. Anyways, good luck on your rebuild.
Dee
motor shop recommendation. They told me that piston to wall clearance was almost twice maximum spec and that oversized pistons would be the solution.
float_6969
I went to 84mm, just because I wanted to.....
