Weber with Anti-Dieseling Solenoid
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
N-Dually
Car: 1986 Nissan 720 Dually
Hi,
Is anyone running a Weber with the Anti-Dieseling Solenoid? Originally I did not, but it would occasionally run-on. I tried to adjust the carb the best I could and I think it is pretty close. So, I bought a solenoid for it and tried to install it last night. When I did, the truck would barely run. I hooked it up to the same wire as the choke.
Does anyone have experience with this?
Thanks.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
no, sorry. and mine only diesels when its hot or the throttle sticks at turn off and keeps gassing it slightly.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
mine never diesels... no solenoid.
N-Dually
synack7350 wrote:mine never diesels... no solenoid.
Yeah well, I am not very good with carbs. Surprised that it runs as good as it does. :rolleyes:
I am leaving the solenoid off. Weber tech keeps telling me I don't need it and the only reason they sell it is because of EPA regulations. Wish they would say that on their site. Would have saved me $20.00.
PEZi
Yeah, I've never had any dieseling issues with my Weber. Sorry man.
synack7350
if I were having those issues I'd check for sticking throttle linkage. Idle set screw (make sure its not turned in so far as to open your throttle plates. Mixture screw If you are exceeding 1.5 - 2 turns out you need bigger jets (as I did at altitude). And fuel pressure but I assume you have that under raps. pressure shouldn't be jumping around. Hope this gives you a place to start.
Return to “Datsun 720”
