Weber!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Bloodman324
Car: 1981 Datsun 720 Kingcab 2WD Automatic
Hey, so i want to put a weber on my truck, and I was wondering: What kind of weber do i have to get for an 81 Z22? and where will i be able to purchase one for a reasonable price?
PEZi
I'd suggest this with one of these. I'd never look anywhere else for a Weber either.
Bloodman324
Thanks! haha not a bad price either lol Oh and one more question, how easy is it to install one these bad boys? haha :chuckle:
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
its really not that bad. I'd never done it before and it took me all of about an hour to get it all hooked up. Vac lines are a pain its suggested to go ahead and do a vac delete while you're in there if you haven't already. I have a bunch of pics on what it should look like on my thread. Oh never use rtv with gasoline! just saying...
Bloodman324
Oh nice haha I would like to see how you would do a vac delete so that way when i do go to put a weber on i can do that as well haha and ok thats good to know!! what is rtv anyways? Oh and by the way I love what you did to the interior of your truck! looks good haha how did you recover your door panels to look like the original? (the gray lines)
synack7350
vac delete is easy the only vac line you need in the whole truck is the one to the dizzy advance the rest can be discarded and the ports capped. RTV is room temperature vulcanizer its commonly called gasket sealant it comes in two flavors blue and read for cold and hot respectively. You usually see generous helpings of the red stuff on various gaskets, as it does a wonderful job gasket sealing. It's just not to be used in fuel applications as fuel will just break it down. the door panels I used new vinyl I got from a local interior guy for like 15 bucks I think it was 2 yards of fabric but I'm not sure. I glued the vinyl to the removed panels via spray on adhesive. then taped those lines and used charcoal gray vinyl spray paint. Came out looking pretty clean :).
Bloodman324
Oh ok well thats good to know haha and ahh i see lol gotcha and thats cool what you did with your panels haha i need to cut a whole new panel for both doors, oh and by the way, your new accelerator pedal pad is upside down :crazy: I had that same set of pedals on my old truck and the wide part of the pedal was at the bottom, just sayin haha
Return to “Datsun 720”
