float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Oct 15, 2005 6:26 am
OK, first of all, I'm sorry about the problem you're having.
The problem is that you need to use a water pump from an S12 with a CA18ET. We have found that using a FWD CA18DE water pump can cause problems. If you get a FWD water pump, that fixes the problem sometimes, but not always. I haven't heard of anyone haveing problems with the CA18ET water pump.
If possible, return the pump(s) you've got, and get one from a CA18ET.
