No real cons to it, unless your injection system gets clogged or you run out of meth/water and still run your high boost. Then you could grenade your engine. The Snow kit has a safety add-on to address that.carsonsowers wrote:I have always been curious about it. I know the muscle car guys have been using it for ages but I haven't ever really seen it talked about for anything else. Pros? Cons? Anything? I think I remember the autocross slicktop guy talking about it a long time ago.
What? Were those even sentences?vulcanrush wrote:i think there is a con to it, and why i probably won't run one (other than the fact that i'm not smart enough to install it).
the system won't turn off, it would screw up your engine.
if the specialty-z guys won't recommend it.
I am, I have a SMC alky system. It's a great system, though I have yet to tune for it. I currently have it coming on at 9psi and shutting off at 18psi. I only have the boost set to 14psi.vulcanrush wrote: are you running it on your own car, bigtdogg?
OK, good article, and some neat info. But let's be clear. He had driveablity issues on a system using a windshield washer pump. That produces about 1/5 the pressure required to atomize water. Snow, Aquamist and SMC systems use 90-100 psi pumps to create the required mist. I'm not saying Mike's not a smart guy, but he was admittedly tinkering. The Evo that blew up? Failed hobbs switch. Sh_t breaks all the time, and this is just another thing that can go wrong, true. But like evildky said, there are many other things that could grenade your engine before a water injection system.vulcanrush wrote:there are issues such as driveability issues.
nope not yet, I kicked it aroud and just never got to it, I do intend to add it to my S30 when it goes back togethervulcanrush wrote: it's true that these systems have been around for a while, but to say there are no cons is incorrect, imo...there are issues such as driveability issues.
do you run one of these systems, evildky?
SpecialtyZ =/= UltimateZevildky wrote:you should hit the SEZ )now called the DNI shootout) sometime, you cna see lots of meth injection in action
fwiw I don't thinkg ultimate z has much interest in extreme performance stuff, I spoke with them first jeez, 10 years ago!? and they were recomengding all stock parts at that time
specialty-z is all about extreme performance, they're a pretty high-end shop.evildky wrote:you should hit the SEZ )now called the DNI shootout) sometime, you cna see lots of meth injection in action
