liteemup39496 »
https://forums.nicoclub.com/liteemup39496-u63343.html
Thu Sep 04, 2008 8:42 am
for good measure
watercooling kit consist of Thermochill HE120.3 rad, Swiftech Storm G4 cpu, Swiftech Stealth GPU, MCW30 chipset, Liang D5 vario pump. EK250ml Res, Tygon 1/2in id - 3/4in OD tubingdistilled water, cap of zerex super coolant and about 25 drops of feser black UV dye
rig= e6600 @ 3.4ghx (426x8 1.30v) gigabyte p35-ds3r8gb ddr1000 gskill ram ($175 shipped cant go wrong)8800gts 320mbxfi xtreme music6 hard drives
yea ima car nut and a nerd... owell
edit: my rig is completely quiet, barely audible i am getting currently as of typing this about 44c across the board, mind you ambient is 90f . night time or early morning it idles low 30s, winter time we will see how low she goes.
btw most expesive things in your loop should be the rad and pump. if youpln to stay WCing i suggest buy the best rad you can afford ie feser or thermochill. blocks can be had for 50-60 bux as for pumps do not skimp out on a decent pump you will pay for it if you do. either d5 or if you wanna go aquarium pump i suggest the pondmaster series get the 200gph or better i have a 900gph and its huge and heavy and loud as **** but she can mooooooove some water
