709Z32 »
https://forums.nicoclub.com/709z32-u267346.html
Tue Oct 25, 2016 2:31 pm
Hey guys, im having a persistant issue thats been bothering me. I have done plenty of research on this car, and need a little guidance.
My JDM tt always had a starting/running issue since i got it from japan. Dug into it, had code 34. Cleaned terminals, reset codes, never returned. Started fine about 3 times, after that hot or cold it would hesitate on startup. Ran codes, code 21, checked all wires, found out i had a bad ptu, and the connector pins were all corroded apart. Replaced ptu and wiring back to where it joins the main harness. Hesitated on startup still, but runs great.
Checked codes, code 13. checked, signal good, ground good, ect reading out of range. Tried to start without it plugged in, starts perfect. Went next door to nissan at work today, managed to get one in stock! Came home, installed it. Started several times on cold start waiting different lengths of time. Starts awesome. Warmed up, checked ignition timing, 15 degrees. shut off, started, annnddd hesitate. still much much better then it was prior to ect replacement, but it chokes for about 2 or 3 seconds bad.
Unplug ect, starts fine every time. If i let it sit for a few minutes in between warm/hot starts it starts pretty good, not perfect though. Unplug ect, perfect starts. All of this is in between resetting codes. When it cools down it starts perfect again.
So I ran the oxygen sensor test, the blinking of the light are long and far between. The left will stay on for about 2 seconds, go out for 3, 4, 5. The right side has better response, but still sluggish. I have nothing to compare it to, but i feel like thats not right. By rights it should blink almost constantly for very very short periods of time. I also get black water/unburnt fuel out of my right tailpipe. Its obvious i may have bad oxygen sensors, but would that really cause that bad a hesitation on warm startup in these cars?
My prvr is already deleted. I also have a bad fan clutch, but that wouldnt make a difference. My very cold start ignition timing is 40 degrees. Sorry for the long read, any advice or guidance from some people whove been down this path would be great! It seems like im going in circles replacing and testing, it runs so well when started compared to when i got it, and with every fix im getting happier and happier with the car and how it performs. Thanks in advance for any input.
